no start! Help
Has good spark. Brand new distributor. Checked valve timing-perfect. Checked cam and crank keyways-intact. new plugs and wires. Swapped entire wiring harness from known good spare unit. Swapped LPG regulator from known good spare unit. compression is 175 at all 4 and holds. Problem-cranks and back fires out intake. Will not start. Checked timing multiple times and still no success. Any ideas???
  • Posted 1 Oct 2013 03:58
  • By paul_r
  • joined 27 Jun'13 - 5 messages
  • British Columbia, Canada
Have you checked the governor and throttle plate to see if they are opening? Have tried starting fluid?
  • Posted 2 Oct 2013 11:55
  • By rogeriwt
Backfiring is a timing issue. Does this unit have the ECS system (no throttle cable- drive by wire)?
If you say the valve timing is spot on & the ignition timing is spot on- then I would suspect that the electronics are failing. I have found that when Toyota electronics begin to fail, they need a HUGE adjustment of the distributor (usually advanced) to get them to start, then backing off of the ignition timing to keep them running.
  • Posted 2 Oct 2013 01:04
  • By bbforks
Seems to me that if the compression is good on all cylinders, and it's backfiring through the intake, something has to be wrong with when it is sparking.
  • Posted 1 Oct 2013 08:19
TCM FD115-3
Aichi SR18A
ROYPOW
TCM FD115-3
Aichi SR18A
