BT RR E2/14 SN.283537AA '1996
Hello All, I have a problem with the above mentioned reach truck.
The problem is no drive function with no error message on the display other functions (hydraulic and power steering) are working well. The brake is going of and only if we hold the forward reverse switch in it's position and we accelerate the contactors are closing.
Is there someone that can help me in the wright direction, I don't have a lot experience with BT.
Thanks already
marcb
  • Posted 7 Aug 2013 01:16
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Yes it was, thanks again
marcb
  • Posted 7 Aug 2013 22:03
  • By marc_b
  • ANTWERP, Belgium
Good to hear it was a nice cheap easy repair.
  • Posted 7 Aug 2013 20:39
  • By Forkingabout
  • england, United Kingdom
Hey Forkingabout, million thanks for your reply. It was indeed the switch in the accelerator (with a flat spot). I replaced it and works again.
Kind regards
marcb
  • Posted 7 Aug 2013 19:37
  • By marc_b
  • ANTWERP, Belgium
It's been 5+ years since I last saw / worked on a Reflex DC.
It sounds to me like the creep speed on the direction switch is working ok but there is a lack of any throttle pedal input for traction.
I'd check the throttle pot values at the A5 card under the armrest.
Pin 910 - Wire number 29 should be +12 volts.
Pin 911 - Wire number 30 should be 0 volts.
Pin 601 - Wire number 50 is the input to the card, voltage should be variable depending on pedal position.
I remember on older smaller BT DC equipment we used to get an issue with the small roller wheel on the microswitch inside the throttle pedal unit, it used to get a flat spot on it & cause non traction issues - I cant remember if the DC Reflex has this exact same set up.
  • Posted 7 Aug 2013 01:56
  • By Forkingabout
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Sioux Falls, SD, United States
In 1923, French tennis player René Lacoste was promised a crocodile leather suitcase by his captain if he won his next match. He lost the match but won the nickname "the crocodile" which he had sown onto his tennis attire. Ten years later he launched the first polo shirt and Lacoste, the first brand to feature a logo on its clothing.
