No Lift and No Lower
i have a Tsp truck that has no lift/lower, the truck drives fine. handset is coming up with code 59. has anyone out there ran into this?
side note, the contact tips are fine, the encoder is indexed and and has full sweep, when you give the lift comand the contacts do not pull in. checked the ossilator card and couldnt see any burnning. i know there is another card for the lift command but havent checked it yet
thanks
  • Posted 16 Feb 2013 14:02
  • By VAN_CEN
  • joined 8 Nov'11 - 22 messages
  • British Columbia, Canada
pretty sure f59 is raise/lower servo
located about middle of hydraulic wall, sometimes gets stuck
  • Posted 22 Feb 2013 16:57
  • By crownie
  • Victoria, Australia
VETTER Forks, Inc.
Ncn 110TH
Ncn 110TH 2015
TCM FHD105Z
VETTER Forks, Inc.
