Toyota 4fg25
Toyota 4fg25 - gas engine will not start. Have spark but spark is weak. Carburator runs rich. Put new kit in carburator excluding new float, but still runs rich. Replaced plugs, wires, rotor and coil but no help. Any suggestions would be great. Manufacturered June, 1983.
  • Posted 3 Feb 2013 07:14
  • By farmerg
  • joined 3 Feb'13 - 2 messages
  • Washington, United States
I am with Huckleberry, We have seen bad points, rotor, cap, Condenser (on the side of the dist) and wires. For the price I would put a copmlete ignition kit in. If you suspect a bad spark??
  • Posted 12 Feb 2013 23:05
  • By Prentice
What about points or is this unit electronic ignition , points should gap at.017 also what engine does this unit have ?
  • Posted 12 Feb 2013 13:13
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
Spark should jump a minimum of 1/4 inch and be bright blue. If spark is yellow or orangem or won't jump that distance, spark plug fouling will result, along with drivability issues under load. Again- where did the parts come from for the tune up & what brand were they?
  • Posted 5 Feb 2013 23:08
  • Modified 5 Feb 2013 23:08 by poster
  • By bbforks
When holding plug wire to ground we do not see the big spark or big pop you see on other engines. Feeel carburator is running rich in that plugs foul quickly and by observing amount of gas entering carburator.
  • Posted 5 Feb 2013 20:47
  • By farmerg
Describe what you mean by weak spark- weak spark can give the symptoms of a rich carb. Where did you get the tune up parts you put in?
  • Posted 5 Feb 2013 00:59
  • By bbforks
SMV (Konecranes) 33-1200C
UN Forklift FD15-18T
