cat dp30n
can anyone help with an intermittent loss of drive fault
the truck looses drive , neutral light and fault code p-22 comes on dash,driver puts truck into neutral and then back in to forward or reverse and regains drive for a while,
has anyone got a wiring diagram for the truck
thanks for any help.
  • Posted 15 Nov 2012 04:47
  • By markg
  • joined 27 Oct'09 - 57 messages
  • n lincs, United Kingdom
We had a couple of faulty fwd/rev drive solinoide on the top of the trans
  • Posted 15 Nov 2012 23:45
  • By Prentice
thanks edward , i'll check switch and wiring.
  • Posted 15 Nov 2012 18:20
  • By markg
if no one has installed and incorrectly wired in a backup alarm, this is a bad directional switch or the wiring to or from it. I was just mentioning a p22 code in a different thread. P22 is either no signal in any direction or neutral, or a signal in more than 1 position (ie., a signal in both neutral and forward or reverse), from the directional control lever to the {can bus of} vcm/ecm/display panel
  • Posted 15 Nov 2012 11:13
Muncie, IN, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Ncn 110TH
Ncn 110TH 2015
