Jungheinrich EKS110
HI there
Can anyone help with perhaps a service manual or parameter settings for a Jungheinrich EKS110 L100-160E serial is 91514369.
We have a problem where after raising the carriage once it passes the 2 magnetic switches which are together under the keyswitch assembly area it cuts out the lifting and traction. If we activate the switches with a magnet then it continues to the top and then only cuts out lift motor once it reaches top magnetic switch, however we still get drive as it should.
The problem is the cutting out of drive and lift halfway through after passing these 2 switches inside the carriage area.
  • Posted 29 Sep 2012 03:24
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hi Mate
Yes seems to be sensor related as after we activate it again it works. Just thought incase it was a setting issue which could be turned on and off in the settings perhaps. Will get customer to replace the switches/sensor.
Thanks
  • Posted 1 Oct 2012 01:05
  • By elektrodrive
sounds to me like a bad sensor or maybe just an adjustment gap between the sensor and the trip plate?
most of the magnetic sensors have an orange light that lights up when they are turned on
check this when it passes the trip plate
  • Posted 29 Sep 2012 14:35
  • Modified 29 Sep 2012 14:35 by poster
Taylor TX330S
USD159,500
UN Forklift FD30T-NJM1
