Allis Chalmers Model FPB 20 24 Forklift info needed?
Anyone know any info (weight rating, max mast lift height, engine make...) on an Allis Chalmers Model FPB 20 24. I assume the 4 cylinder engine is made by Continental? Is the lift capacity 1 or 2 K? Can parts still be obtained for an old Allis Chalmers forklift?
  • Posted 26 Sep 2012 14:36
  • By Broncobilly
  • joined 26 Sep'12 - 7 messages
  • Illinois, United States
TIA!
Broncobilly
I found out I was wrong on the manual trans clutch, on the Allis. It has a shuttle shift type clutch.
  • Posted 29 Sep 2012 11:24
  • By Broncobilly
TIA!
Broncobilly
I would think that has a clutch petal and not a clutch lever on the shifter. Brake parts are available, it's everything else that may be a problem.
  • Posted 28 Sep 2012 21:08
I finally got in touch with the seller of the Allis Chalmers forklift. I emailed my cell # to him, and he rang me up this evening. Here's what I found out. He has had the lift for 3 years. He got it in a trade, and really hasn't used it much. Says he starts it a few times a month, and it fires ring up. The brakes did work when he got it, but not longer do (probably can't get brakes for that old of a lift now?). It can lift 1 ton. Mast max height is 7'. The mast can also tilt forward. The engine is a Waukesha model FC 133 4 cylinder. It is a manual trans. I believe the clutch lever is on the shifter. Basically you pull in a motorcycle like handlebar lever (on the vertical shift lever), move the stick forward or backward, then let out the hand lever (as you would a clutch on the floor of an automobile). So I guess I have to make a decision now?
  • Posted 28 Sep 2012 11:49
  • By Broncobilly
TIA!
Broncobilly
John,
That's true! Unfortunately; the seller is 250 mi from me, so I can't just hop in the pickup and have a look at it. His feedback score on Ebay is pretty good. Still waiting to hear from seller with info on the lift.
  • Posted 27 Sep 2012 13:15
  • By Broncobilly
TIA!
Broncobilly
Be careful if the seller is only wanting to sell it for $500 it can't be much. That is about what you can get for it at a scrap yard.
  • Posted 27 Sep 2012 12:42
  • By johnr_j
John,
Thanks much for that helpful info, especially the contact phone #. I really appreciate it! I emailed the seller of the lift yesterday, and still haven't gotten a reply. If the lift is in operating order, I will probably buy it, as the price is right ($500). I can always upgrade at a later time.
  • Posted 27 Sep 2012 11:57
  • By Broncobilly
TIA!
Broncobilly
Here is a little help;
1. The unit has a basic lift capacity of 2000 lbs. At 24" load center
2. The engine is a Waukesha model FC 133.
3. Make lift height would depend on what mast is installed on the lift - two section or 3 section & what the mast collapsed height is.
4. This a unit that is very old at least 30 years parts are hard to find as A-C has disappeared.
5. But there are two people I know of in Illinois (Alsip) that might be able to help you they work for the Komastu forklift factory store in Chicago - Scott Eller & Bob Halverson. These guys are old A-C guys and probably can help. tele 708.385.0330.
6. Try to find the serial number either on the nameplate or stamped on the frame.
  • Posted 26 Sep 2012 21:23
  • By johnr_j
"Have An Exceptional Day!"
Deborah Baker Deborah Baker
Terberg RT223
Taylor TX330S
USD159,500
Muncie, IN, United States
