Linde H50D H2X394
Truck will not drive and engine does not rev up when using hydraulics. Lift and tilt functional. If you hook up pathfinder there are no codes other than cold start valve engaged, if you attempt to drive code 107 comes up on pathfinder with the description drive attempted for greater than 2 seconds with cold start valve engaged. Does anyone know how this cold start valve works and why it is engaged with a truck in summertime conditions?
  • Posted 5 Sep 2012 11:33
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Hi
As I know, Linde has been replacing the turbo charger of all truck model H50D H2X394 free of charge since it is a system error from Turbo charger supplier.
Please swap over the turbo charger from the other truck to see if the problem come from it.
You can contact your Linde Dealer in local to request them to replace the new one and flash the new software in order to synchronize with the new type of Turbo charger.
Nuna
  • Posted 10 Sep 2012 16:03
  • Modified 10 Sep 2012 16:05 by poster
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Switch the truck off and gently lift the drive pedal a few millimeters while starting the truck and try again , code 107 is almost always present
cheers
  • Posted 9 Sep 2012 01:02
  • By majbm
  • joined 15 Mar'12 - 10 messages
  • yorkshire, United Kingdom
ok read the vw engine with laptop
  • Posted 5 Sep 2012 15:55
  • By michel_v
  • noord holland, Netherlands
check your coolant temp or temp diesel
  • Posted 5 Sep 2012 15:53
  • By michel_v
Taylor XC300M
New - Sale & Hire
UN Forklift FD50T-NJB3
Taylor XC300M
New - Sale & Hire
Lift Technologies Inc.
Deborah Baker Deborah Baker
Muncie, IN, United States
