Crown FC4010-40TT
Does anyone know how to do a voltage change from 36 to 48 on a Crown fc4010-40tt188 s/n9a149496
  • Posted 29 Aug 2012 02:26
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Hi. Hope u have an LX handset. you will need this to change functions with in the control card.
First of all you will need to change SV1, SV2,K1,K2, Operator Fan, back up bulb, if your truck is a freezer truck you will need to change RES1,2 and 3. Part numbers repectively for SV1 and 2 127269-002, K1- 062640-003,K2 - 062711-002, operator fan - 127259-006, back up bulb - 117994, RES1 thru 3 - 130117-002.
Now you have all the parts you will need to change some parameters in the traction card. Functions 2, 12, 14, and 15 will require adjustment.
Change function 2 from 125 to 90
Function 12 from 61 to 90
function 14 from 25 to 16
function 15 from 38 to 57
hope this helps.
  • Posted 1 Sep 2012 09:47
  • By julesrobdog
  • joined 13 May'09 - 11 messages
