Jungheinrich ETV 214 Series Problem
hello how are you Sir?Sir I need your advice for fixing Jungheinrich ETV series 214-115-840 DZ S/N:91055824 Years 2011
the problem is Error Code 110.the effect is forklift speed is very slow motion.
any advice for his?please advice and thanks for your kindly attention and good cooperation.
  • Posted 2 Aug 2012 13:02
  • By stillengineer03
  • joined 4 Nov'10 - 47 messages
  • Singapore, Singapore
George Peter
georgepeter03 at gmail dot com
Hi,
Error No. 110 => Current output faulty
relative Component: MFC brake
Check outputs for short circuits
=> the truck will be slow speed.
This means that one of the output from MFC brake is short circuit.
You need to find out the MFC brake is a grey box - rectangle which is located near by the knee of the diver above the acc. pedal.
Check and find out which output short and solve it.
Do you have the drawing of this truck ?
Good luck
Nuna
  • Posted 2 Aug 2012 18:28
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
Muncie, IN, United States
Combilift Ltd
