I need help with a Toyota RRB3
Hello,
I have a toyota forklift, is a electric machine, the model is: RRB3 and i have a problem.
The machine dont start, and i detected a principal contactor, i when forze this contactor the machine start, but if i off machine this no operate.
When the machine is start with the forze contactor, the machine in the display show the code
C025 or E104
I dont know what is this, i havent the manual of the machine, and i want know if you can help me.
I need the Service Manual or Fault Manual.
Thanks you.
Sorry for my bad english
  • Posted 16 Jun 2012 10:20
  • By yangsteven_g
  • joined 16 Jun'12 - 19 messages
  • Engativa, Colombia
Hello, I can repair this machine, the problem was a bad wire in the k10 contactor.
I replace this wire and the machine now is enable.
Thanks for your comments
  • Posted 11 Jul 2012 22:28
  • By yangsteven_g
Thanks for the information, today i prove the Fuse F60.
Forkingabout you can help me with the Service Manual for BT RRB3, about electrics
  • Posted 20 Jun 2012 23:29
  • By yangsteven_g
Pin 807 / wire number 24 on the A5 card is the ignition start wire, stick +48 volts on to this & see if the truck starts up.
There is +48 volts on pin 805 / wire number 21 from fuse F60 you can use.
F60 should be the top 10 amp fuse in that fuse holder inside the motor compartment.
I take it you have stuck your hand up the dash & checked the keypad is still plugged in, I have had one come undone before where people like to have a fiddle.
  • Posted 20 Jun 2012 20:09
  • By Forkingabout
  • england, United Kingdom
When i revised the machine, arround of the motors (direcction,traction and hydraulic) i see a module, in this module have 4 fuses, i tested this fuses and all is correctly. When you say F60, is one of this fuses in this Module, or the fuse F60 are inside of motor?. Thanks You can helpme with the service manual please?
  • Posted 20 Jun 2012 01:47
  • By yangsteven_g
Thanks
  • Posted 20 Jun 2012 01:33
  • By yangsteven_g
It sounds like the F60 fuse has blown & this is the main ignition fuse.
The truck will appear totally dead with this fuse blown.
If the F60 has blown check the horn & the 2 cooling fans, ive had it before where the horn has shorted out when the horn push button is pressed & the truck just shuts off.
  • Posted 20 Jun 2012 01:26
  • By Forkingabout
Hello, more later i test the Fuse F60 in this moment dont have the machine. When push the buttons of thhe keypad, the leds are off, the machine not responding. But if forze the contactor all the machine is On.
Thanks, sorry for my bad english
  • Posted 20 Jun 2012 01:20
  • By yangsteven_g
Check the F60 - 10 amp fuse.
Has it got the factory keypad on the dash?
If it has are the red or green lights showing when you press any of the buttons?
  • Posted 19 Jun 2012 17:34
  • By Forkingabout
Hello Forkingabout, Thanks for your answer, the serial of the machine is 6024205/2008, i am grateful if you can help with the manual of this machine.
Tomorrow i test the points the coils resistance, and the fuse of motor.
  • Posted 19 Jun 2012 10:11
  • By yangsteven_g
from my experience if you pull in a contactor without the system calling for it you will get errors.
i would fix the powerup problem first...
then IF the codes are still there troubleshoot those then
if the codes dissapear then all is well and your on your way :o)
  • Posted 16 Jun 2012 23:02
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Hi
This is really a BT Reflex with Toyota stickers
Is the machine totally dead until you pull the K10 contactor in?
Check the F60 - 10 amp fuse inside the motor compartment, this is the main system fuse that controls the ignition circuit.
C25 = General CAN BUS fault - look in the error log for the code thats flagged this.
E104 = Parking brake fault - Check the service switch under the dash panel, you have to remove the arm rest panel ( lift the cushion & remove the wing nut ) its the switch on the left as your sitting on the truck, it can get knocked if the arm rest panel is refitted incorectly.
Check the brake coil is connected, measure the resistance over the coil.
Cable number 40 is the battery minus & cable 64 is the brake output from pin 802 on the A5 card under the armrest ( the big silver card )
Need the serial number to get the exact manual as there are several ( electrics & hydraulics are different )
  • Posted 16 Jun 2012 20:44
  • By Forkingabout
Toyota 8FD45
Toyota 3FD100
Muncie, IN, United States
Toyota 8FD45
Toyota 3FD100
Deborah Baker Deborah Baker
