Cat NRR30 / 2NL00864
ERROR Codes 30,44,60 on display. Does any one know what these's codes mean? Note thes's codes show up every once in a while.
  • Posted 10 Jun 2012 00:03
  • By ben_g
  • joined 12 Feb'08 - 60 messages
hmmmm....
code30 = drive motor encoder output signal fault
possible causes are:
- defective encoder
- loose or broken encoder belt or related hardware or wiring
code 44 = PC contactor detected closed when commanded open
- defective coil driver
- welded PC contactor tips
- binding contactor plunger or related hardware
- bad contactor panel harness
- vehicle manager defective
- PC sense circuit defective (distribution board, PC sense line, power panel driver assy, or VFC)
code 60 = are you sure about this one? was it 6C maybe?
there is no code 60 in the manual that i can find.
if it were me i'd check the battery first, make sure its not discharged or defective or grounding to the frame in some manner
  • Posted 10 Jun 2012 15:09
  • Modified 10 Jun 2012 15:11 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
THANKS KEVIN.
  • Posted 10 Jun 2012 01:38
  • By ben_g
Muncie, IN, United States
Deborah Baker Deborah Baker
