Jungheinrich EFG DF16LSP GE90, error 81
Good day, Can someone help me with a problem we're having on a Jungheinrich, the problem is error 81 (reset parameters). After changing the standart parameters and accelerator the truck runs fine but after a month it gives back the same error. We had to made these settings already for the 3the time now. Can someone give me an idee to solve this or has the same expirance?
Many thanks
Marcb
  • Posted 25 May 2012 23:22
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Write the machine serial number.
I did.
-swapped left for right electronics.
-in service menu to load the machine type and standard parameter. / grundstellung /
-if the error transferred Check power supply.
  • Posted 28 May 2012 23:21
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Hello Geroj, thanks for your reply.
Left electronics of the drive controllers is giving the error. What did you do to prevent this from happening again? Electronics at the wheel, do you mean the interface cards behind the right front wheel? No I don't have any electrical diagram of this machine, It would be helpful.
marcb
  • Posted 28 May 2012 18:00
  • By marc_b
  • ANTWERP, Belgium
Flashing electronics which is the error.
Check volts power supply, power cables.
Do you have a diagram?
I had this problem.
Machine working in wet environments.
Damaged electronics at the wheel.
  • Posted 28 May 2012 14:54
  • By geroj
  • Krivan, Slovakia
Thanks all for your replies and suggestions. Electrodrive if I understand your answer correctly you think that the model has been wrongly installed, When plug in LISA we have the model EFG DF so I believe this must be wright? This truck works in dammed conditions (manufacturer of bleach products). Next time when we have this problem I will change the 2 drive controllers from place and see how it goes.
regards
marcb
  • Posted 27 May 2012 03:50
  • By marc_b
  • ANTWERP, Belgium
Hi
The left side travel electronics stores information about the machine. Try exchange for the right electronics. Standardparameter upload again.
  • Posted 26 May 2012 14:22
  • By geroj
  • Krivan, Slovakia
HI Mate
Try going through change truck settings and reset truck type, then reset standard truck traction, pump, steer parameters. I have had a customer have a similar problem caused by water damage on the interface card and dash display.
  • Posted 26 May 2012 02:35
  • By elektrodrive
enquiries@elektrodrive.co.uk
Muncie, IN, United States
