Nissian, LP truck E32
Anyone know what a code "E-32" would be flashing on the dash while driving, seems to run ok. Thanks
  • Posted 9 May 2012 20:04
  • By stephen_j
  • joined 4 Nov'11 - 34 messages
  • Indiana, United States
Thanks
  • Posted 12 May 2012 00:37
  • By stephen_j
e32 fault is overheating due to water or transmission
both are on the the line you have stage 1 and stage 2.
i have this problem with a couple of truck i look after if the themosat has gone it will over heat all the time make shore rad is clean and air filter is clean and the transmission box is clean.
if truck is use at high revs and been use in small areas the truck will get very hot and keeping foot on inch pedal make shore oil is clean after cleaning truck fault not there reset code fault
  • Posted 10 May 2012 04:23
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
stepson;
Sounds like an overheating issue to a fuel injected LPG engine.
  • Posted 9 May 2012 23:03
  • By MEngr
  • Missouri, United States
ํYOU have a Model of the truck
  • Posted 9 May 2012 20:59
  • By songyot_v
  • joined 8 Jul'11 - 103 messages
  • Thailand
October 8-9, 2025 - Twickenham, United Kingdom
edition #1239 - 17 July 2025
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
The origin of "love" as the score zero in tennis is debated, but two main theories prevail. One suggests it's derived from the French word "l'oeuf" (egg) which resembles the shape of the number zero. The other proposes it's related to the Dutch word "lof" meaning "honour" as players might be playing for honour when scoreless.
