HELP FAULT CODE 524230-30
Can anyone help me w/ fault code, Yale forklift, code: 524230-30. SN B875B17788F.
Best Regards!
Gabriel
  • Posted 24 Mar 2012 04:10
  • By gabriel_p
  • joined 24 Mar'12 - 3 messages
  • nuevo leon, Mexico
'Vivere militare est', Seneca.
Did you happen to remember what fixed this issue?
  • Posted 26 Jun 2018 09:17
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
Gabriel can you fix this problem? I have the same fault. I have the same fault.
  • Posted 26 Oct 2016 14:37
  • Modified 27 Oct 2016 10:46 by poster
  • By jesus_v
  • joined 26 Oct'16 - 2 messages
  • Not Applicable, Mexico
THANKS TITUS, I'LL TRY.
REGARDS!
  • Posted 3 Apr 2012 04:38
  • By gabriel_p
Tail mark driver out put is to low check all rear lighting and change any that are not working these units are LED units now also you can now get a soft wear update to put onto your VSM so that your engine keeps running when a light fails, but ypu will have to get aYale engineer to install it.
Regards Titus
  • Posted 27 Mar 2012 03:22
  • By Titus
  • joined 6 Jul'10 - 185 messages
Thanks Titus. The right code is 524230-3, not -30, but I have change the relays and the engine shutdown in 30sec after start it. I have tested the relays too. Also another equipment SN B875V01909F marks the code 882-4, any idea abut this?
Regards.
  • Posted 25 Mar 2012 03:27
  • Modified 25 Mar 2012 03:30 by poster
  • By gabriel_p
Hi Gabriel,
I think the problem lies in the Power disribution box code referes to rear work lamp relay being defective, the relay is RL7 maybe you can swop it with another relay and check to see if rear work lamp is working.
Regards Titus
  • Posted 24 Mar 2012 18:44
  • By Titus
Enforcer FLBAXT25
Enforcer FD50T-MMA
Michel Denis Michel Denis
