Clark ESX15 Fault Code AL001
When key is turned in the on position fault code AL001 is displayed on the LED display. book says this code is parking brake switch open. Brake seams to be holding when electric foot pedal is released. Can someone help me with checking out the cause for this code.
  • Posted 29 Feb 2012 00:37
  • By robbie_d
  • joined 29 Feb'12 - 3 messages
  • Virginia, United States
I will check sw/link and update what I find
  • Posted 2 Mar 2012 00:16
  • By robbie_d
Robbie Dot Davis at dom dot com
  • Posted 2 Mar 2012 00:12
  • By robbie_d
It should be the pedal switch., I have not work on htese particular trucks so it may be a switch on the pedal or may be on the linkage. I would check and switches with a meter.
  • Posted 1 Mar 2012 09:58
  • By rogeriwt
This a stand up electric truck or a sit down rider? I would check the operation of the switch to see if its faulty. Code 001 in info i have says seat switch fault,but cant be right if it's a stand up electric.
  • Posted 29 Feb 2012 09:23
  • By kevin_t
have an email to post? have to post as mine is so site dosent strip it out.
  • Posted 29 Feb 2012 09:18
  • By kevin_t
