Toyota bulletin (?)
Does anyone have a copy of the bulletin for the lift/lower valve on Toyota 8FGU25. P/N for the replacement parts is 67609-26601-71 superceeded to 6709-26600-71.
Would like to purchase only the broken spring, and not all the pieces.
Any info is appreciated
  • Posted 19 Feb 2012 22:04
  • By 7777
Yup. Someone sent me a copy.
  • Posted 21 Feb 2012 14:09
  • By sleepywheel
  • joined 18 Jan'08 - 77 messages
  • British Columbia, Canada
sleepywheel at gmail.com
Did you find the bulletin yet?
  • Posted 21 Feb 2012 09:28
  • By FF81
  • joined 13 Aug'09 - 15 messages
thank you
  • Posted 21 Feb 2012 06:42
  • By 7777
I ordered the 67609-26601-71, the other number changes up to that number. The number change is usually used to differentiate between their suppliers.
  • Posted 21 Feb 2012 06:36
  • By sleepywheel
You have to remove the control valve. The lowering spool activates a 5 volt(?) switch, which activates a 12 volt soliniod, which in turn allows for oil pressure to release spring pressure lowering the load.
If you remove the soliniod, you'll come to the 1st spring and poppet, then you'll see a hollow cigar shaped holed cylinder regulator valve. Remove that and you'll see a broken spring, thats the problem.
P/N is 67609-26601-71, 67609-26600-71 (5000lbs). There are 2 #'s listed on the parts sheet and only the second # is listed on the bulletin. I dont know if they are the same part. E-mail address?
What p/n did you order and where did you get it?
  • Posted 20 Feb 2012 18:46
  • By 7777
I just bought the kit for an 8 series unit that I'm working on. What is the problem that you've got that requires the spring? Mine is slow lowering speeds.
I'd be interested in the bulletin just to see what it's about. I'm not looking forward to pulling the valve apart. Does the whole valve assembly need to be pulled out or can it be done in the unit?
If you can find the approximate date the bulletin was sent out or a form number, I may be able to get it from my sources.
  • Posted 20 Feb 2012 16:13
  • Modified 20 Feb 2012 16:14 by poster
  • By sleepywheel
Do you know what year this bulletin was released?
I dont fancy looking through all of them ha ha.
I only read the BT ones & rarely bother to read the Toyota ones as luckly I dont have any Toyota trucks to look after.
  • Posted 20 Feb 2012 00:51
  • By Forkingabout
  • england, United Kingdom
Muncie, IN, United States
UN Forklift FB25N1LZ1
UN Forklift FBT20NQZ1
