ERCO80HDN365FO84/A839VO2691w ERROR CODES
How to retreive error codes.EV 200
  • Posted 10 Feb 2012 06:34
  • By kent_w
  • joined 5 Jan'12 - 102 messages
Hi,2 wires go into upper plug of card.Im pretty sure wires are green an white,Ill check today.Do you have a wiring diaghram?Its like it doesnt reset,then you have no For/or rev.untill this link is removed.back alarm does work.but no for or rev. Thanks kent
  • Posted 10 Feb 2012 22:57
  • By kent_w
You will need an LX hand set to retrieve codes, Dose this green/white wire go back go back to the card connector plugs and if so which terminal are there two wires on this cooper link that you loosen of one being a yellow,
Regards Titus
  • Posted 10 Feb 2012 21:18
  • By Titus
  • joined 6 Jul'10 - 185 messages
Toyota 8FD45
Toyota 3FD100
Muncie, IN, United States
