komatsu fb25tex-11
komatsu fb25ex-11 eror code E04 pls help me
  • Posted 4 Feb 2012 21:31
  • Modified 4 Feb 2012 21:32 by poster
  • By songyot_v
  • joined 8 Jul'11 - 103 messages
  • Thailand
yes according to komatsu on this model code 04 is upper FET of travel power module is shorted.
so transistor is most likely suspect
  • Posted 5 Jul 2012 08:09
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
well if it has transistors block burned, please replace also the detector of current, because at deficient detection make a slow or fast signal in an fase and burn at new block or module you replace, in AC machines, in line burnt. it happened to me. when replace a pair of transistor "toyota", the machine stay good four days. a hug for all
  • Posted 5 Jul 2012 07:18
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
thank AMartis.
It is a machine AC traction. I will check.
  • Posted 5 Jul 2012 01:12
  • By songyot_v
  • Thailand
hello my friend.
i think this problem is on transitors of traction. if is a machine AC traction, behind at condensators has three transistors blocks, one is burned or more. check this place, if it is not machine AC, sorry.
say any thing. thank you. look your mail. a hug
  • Posted 4 Jul 2012 09:53
  • By AMartins
I will check it. But it did not work. It shows
failure in cont(T) error EO4
  • Posted 4 Jul 2012 02:01
  • By songyot_v
  • Thailand
VIMONTA_S@hotmail.com
thank Titus
  • Posted 5 Apr 2012 01:20
  • By songyot_v
  • Thailand
Check the ECU connector on the left hand side under battery.
Titus
  • Posted 7 Feb 2012 19:55
  • By Titus
  • joined 6 Jul'10 - 185 messages
Titus
  • Posted 7 Feb 2012 19:54
  • By Titus
thank you i will check
  • Posted 7 Feb 2012 19:09
  • By songyot_v
  • Thailand
I think this is a communication line fault code and I think you will have to check all harness connectors for corrosion and broken wires, and i think you may need to have a laptop to clear code.
Titus
  • Posted 6 Feb 2012 02:10
  • By Titus
Taylor T650L
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Deborah Baker Deborah Baker
