cat c5500 error code
This lift had a code e34 and was called in, traveled to customer tested lift.e34 code was there. On way back I put on the seat belt code went away.Take belt off code returns.The code is tps sensor.Its the only lift at this factory that dose this any clues?
  • Posted 31 Jan 2007 23:38
  • Modified 31 Jan 2007 23:42 by poster
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Sorry accell pot is a tps sensor off what seems to be the old mitsubishi galant car.I learned automotive fuel control long before forklifts.Seat/belt switch powers off key switch
ground by vcm. Power to accell pot from ecm ground by ecm.
Remember most all of the controlled fuel managment systems used today depend on varried power signal from
senders like accel pot.Direct ground would render accellerator inoperable
  • Posted 2 Feb 2007 12:23
  • By proshadetree
E24 is an accelerator pot error which is maybe what you were saying with TPS? But you should avoid using this term as that can confuse it with the throttle body control system.
Edited to remove incorrect information
  • Posted 2 Feb 2007 01:27
  • Modified 2 Feb 2007 19:37 by poster
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
Sorry running by memory which is failing.E24 was the code, lift running like a top for a week now with seat belt fastened behind the seat.Both seat belt and seat switch feed ito the vcm
possible Its going bad?Just a real strange problem.
  • Posted 1 Feb 2007 12:22
  • Modified 1 Feb 2007 12:23 by poster
  • By proshadetree
By the way E34 is related to an ignition system fault and I would be inclined to look towards the IGN relay.
I would suggest that the issue is more with the chassis side of the system than the engine side, due to the belt being an influence. Check your negatives.
  • Posted 1 Feb 2007 03:53
  • By daniel_g
JCB 533-105
Crown SX3030TT4250
Briefs United States
