Release Drive to allow to push
Hi Can any one tell me how to release the drive, We need to push the forklift.
Full details Linde H25D-03 Serial No H2X351M02329/2001
Thanks Nigel
  • Posted 30 Nov 2011 23:55
  • By nigel_p
  • joined 8 Jul'10 - 20 messages
  • Worcestershire, United Kingdom
truck can be jacked up before you start.when its time to use the truck again. screw allen bolt in tight, screw octagon stud in tight and tighten jam nut. if stud is not tight, unit will not stop when driving, it will coast
  • Posted 22 May 2015 11:05
  • By edward_m
  • joined 11 May'15 - 111 messages
on the brake valve their is an allen head bolt, loosen it so that you have about 2 threads holding it. then look down at the air cleaner toward the hydrostat. straight down from the cap of the air filter. their is an octagon stud with a jam nut.jam nut takes a 19 mm socket. I loosen the jam nut and the stud comes with it.screw the nut down till only 2 threads show. screw it back in an tighten. this is to help release the brake.pump brake pedal with your hand untill pedal is tight. jack up truck on 1 side and you should be able to push the drive wheel with your hand
  • Posted 22 May 2015 10:59
  • By edward_m
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 12-1200B
Muncie, IN, United States
USD1
USD1
Kai von Berg Kai von Berg
