Mitsubishi EFB4A
what is the CAT equivalent of Mitsubishi EFB4A year 2004
  • Posted 1 Jul 2011 12:20
  • By gatto_m
  • joined 29 Jun'11 - 9 messages
  • Veneto, Italy
Set the speed or joystick. In setup.After parameters settings.
You put DRS in Setup, and key ON. The first group is speed Hydraulic, in the second group is speed on travel. As caterpillar.
Is equal, CAT and Mitshubishi, Both is MCF ( Mitshubishi Caterpillar Forklift ). Only change colour.
  • Posted 3 Jul 2011 18:19
  • By joram_s
  • joined 5 Feb'11 - 117 messages
  • madrid, Spain
Email soyjoram@gmaildotcom
Thank you.
Only if I want to set the speed or throttle potentiometer, or joystick?
  • Posted 3 Jul 2011 08:10
  • By gatto_m
  • Veneto, Italy
marcogatto272010@libero.it
Yes.
Micro seat open. Is posible Park brake on, too.
  • Posted 3 Jul 2011 06:38
  • Modified 3 Jul 2011 06:39 by poster
  • By joram_s
  • madrid, Spain
Position switch set-up
lever back and then forward.That inverter?,
Push all the 'accelerator
Now turn the key
done on display
I reported all parameters to factory settings?
lifting, throttle setting, speed, etc..?
  • Posted 3 Jul 2011 04:14
  • By gatto_m
  • Veneto, Italy
DRS is equal. Factory settings. DRS in setup. Lever back forward, push acelerator to finish. and key on. In display " Done ".
All parameters, factory settings.
  • Posted 3 Jul 2011 02:24
  • By joram_s
  • madrid, Spain
I think the EP KT series trucks require you to use the DRS switch and the direction levers to access and set parameters through the dash display.
Depends on what you want to set up?
  • Posted 2 Jul 2011 22:17
  • By elektrodrive
enquiries@elektrodrive.co.uk
ok. the facility and the cards are equal?
You know what is the procedure for the set-up and diag on the dashboard?
Thank you.
  • Posted 2 Jul 2011 21:58
  • By gatto_m
  • Veneto, Italy
three wheels or four wheeles, I think EPKT 3 Wheels.
  • Posted 2 Jul 2011 20:21
  • By joram_s
  • madrid, Spain
