speed control
I'm looking for a speed control as low as 3mph for a Toyota 4Y engine. The one Toyota offers is only 6mph. I need speed control not a govenor
  • Posted 12 Oct 2006 01:42
  • By jimc
  • joined 12 Oct'06 - 2 messages
Jim, what is the maximum speed the machine will reach on tick over? You may find that your custoemr request is just not possible.
You've found the right site from SSC (loadingzonesafety.com) as they have a **** of a lot of knowledge, so I would suggest calling them and asking their opinion. If Corky is available then try to speak to him.
  • Posted 27 Oct 2006 03:05
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
There is a product on the market that may suit your needs, its a speed control system that allows different speed zones in different areas, eg. 4mph inside and 10mph outside it is controlled via RFID or GPS whilst not effecting the lifting performance of the truck, performance of the truck may also be monitered via internet if required, if interested please contact via email at [email address removed]
  • Posted 13 Oct 2006 18:47
  • By jase
  • joined 10 Oct'06 - 5 messages
  • Queensland, Australia
Thanks Dave. I was able to find a company in the us that has a unit similar to what you described along with a few other interesting products. The problem i've discovered is that less than 5mph you can overheat the transmission because the convertor is not in lockup.If you want to check out there site it's loadingzonesafety.com. Cheers!Jim
  • Posted 13 Oct 2006 04:51
  • Modified 13 Oct 2006 04:52 by poster
  • By jimc
Hi Jim, do a Google search for Transmon Engineering, they have a product that works the same as the Toyota speed limiter. With a flybywire throttle and dif speed sensor. Don't know if it will go down to 3 mph.........thats pretty slow!
Dave
  • Posted 13 Oct 2006 04:30
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
