nissan transmission
nissan kugho2a30py,how do i get the differential housing to split from the trans i have removed snap ring from pinnion, thanks
  • Posted 18 Apr 2011 05:47
  • By towmotor
  • joined 19 Feb'07 - 360 messages
thanks for your responce, my trans is rusted really bad , i found the seal plugs for both shafts. thanks again MEngr
  • Posted 19 Apr 2011 08:54
  • By towmotor
towmotor;
You have what is best known as a P60 Nissan, started into production abt 93, engine H25 fueled w/ LPG. single spd. F136VB trans and H296 differential. With the differential carrier and drive axle housing seperated and the engine, trans. & differential carrier out of the truck. Seperate the engine from trans case. Remove the torque convertor and remove the oil pump. Pull out the drive pinion's rear end cover. Remove the drive pinion's fixing nut at drive pinion rear end. Remove differential carrier mounting bolts from trans case, and remove the differential carrier sub - assy from trans case with the drive pinion shaft remaining in the differential housing.
  • Posted 18 Apr 2011 09:42
  • By MEngr
  • Missouri, United States
Mobicon 2T
Taylor TT300
USD98,500
Mobicon 2T
Taylor TT300
USD98,500
