Nikki lpg regulator?
Where can I find repair kits for nikki lpg regulators/vaporizers?
I go to SMH but they do not have complete kits.
  • Posted 20 Mar 2011 04:53
  • By dante_s
  • joined 20 Mar'11 - 5 messages
Showing items 1 - 19 of 19 results.
Hey, dante_s
do you still in need of Nikki repair kits and NIkkI LPG set (vaporizer and soleniod ) ? they are for applied for NISSAN H15, H20, H25, K15, K21, K25 and NISSAN, TCM, MITSUBISHI, KOMATSU , If I'm not wrong , the P/N : 17962-00H05 , cost USD196.98/set. kecy (kecy9627at hotmail dot com )
  • Posted 26 Nov 2011 20:03
  • By kecy_w
  • joined 26 Nov'11 - 13 messages
  • Guangdong, China
--not always the correct answers , but should be a correct question
hi, did you purchase from TVH ? i have those kits in stock for my rental fleet maintenance and get it from TVH Belgium via TVHSA, Check www.tvh.com
  • Posted 24 Aug 2011 02:53
  • By arnie
  • joined 17 Aug'11 - 55 messages
  • western cape, South Africa
arnold@rafforklift.co.za
Result: Parts were nearly 5 bills! I was quite surprised.
Was pretty easy to OH, all went well, cheaper than a new unit in my opinion, the way to go...I could do it again pretty quickly.
Thanks again all.
-Jeff
  • Posted 24 Aug 2011 02:49
  • By JeffreyJay
  • joined 17 Aug'11 - 5 messages
It's just an opinion.........I am not saying don't rebuild.Helmar and SMH for around $500.00 to $600.00 depending on what style you have ( Coolant Lines )
  • Posted 18 Aug 2011 21:58
  • By Prentice
I have rebuilt a dozen or more of these mostly because of tar build up in them and taking the diaphrams out and the flapper valve.
  • Posted 18 Aug 2011 06:46
  • By kevin_t
I work for a Forklift Co. that covers many states here in the US and know that the best we can get a new NIKKI Regulator for is about $800-900 US Dollars is MUCH more cost effective to rebuild as it only takes about an hour or 2 to take it out and rebuild and put back in
  • Posted 18 Aug 2011 06:42
  • By kevin_t
My opinion is to replace the whole assembly with new. Might be more cost effective on labor
  • Posted 17 Aug 2011 22:14
  • By Prentice
Thanks in advance, I will give this a try..
  • Posted 17 Aug 2011 03:07
  • By JeffreyJay
Should be NI17960-VR500
  • Posted 5 Apr 2011 22:12
  • By scot_s
  • joined 10 Jun'04 - 63 messages
  • Michigan, United States
Hey Kevin -can you double check the small diaphragm number NI1960-VR500 they say it's missing a number
  • Posted 5 Apr 2011 22:10
  • By troy_m
Thanks everybody, have a great day.
  • Posted 23 Mar 2011 06:17
  • By dante_s
1632-gy010, 17053-fu460, 17054-fu460
these 3 #'s I got alternate sources for, email me and I'll give you the names and phone #'s.
if you have cross #'s for the other parts I may still be able to help
J_CFORKLIFT@YAHOODOTCOM
  • Posted 22 Mar 2011 07:37
  • By 7777
these are the current/to date parts. I carry these on my service van for the company that i work for and have used them on over a dozen NIKKI so far with no problems. We get the diaphrams from nissan and the valve assy from cat just because it is a little cheaper to buy from them.
  • Posted 22 Mar 2011 06:54
  • By kevin_t
Be very careful using the repair parts as these were for older units and these regulators have gone through various changes over the years.
  • Posted 22 Mar 2011 06:51
  • By scot_s
7777 see my previous post i gave the part #'s there.
  • Posted 22 Mar 2011 06:35
  • By kevin_t
Has anyone tried sourceline, if you give me the p/n #'s I'll throw them in and see what happens
  • Posted 21 Mar 2011 18:37
  • By 7777
If looking to buy a new one, cheapest i have seen is item # 120677513433 on ebay. I know the place i work for charges around $900 for a new unit
  • Posted 20 Mar 2011 10:02
  • By kevin_t
NI16328-GY010 O-RING KIT
NI17053-FU460 DIAPH ASSY-1ST (PRIMARY)
NI17054-FU460 DIAPHRAM ASSY (SECONDARY COVER)
NI1960-VR500 DIAPHRAM ASSY (THE SMALL ONE)
NI16065-GY010 SCREW/WASHER KIT
CT91H2004460 VALVE ASSY
Drop the NI for the Nissan part # and the CT for the CATERPILLER valve assy.
  • Posted 20 Mar 2011 09:54
  • Modified 20 Mar 2011 09:59 by poster
  • By kevin_t
havent found a complete kit, have to get all the parts seperately. Mostly will need the primary and secondary diaphrams and the valve assembly can get them thru nissan or caterpillar they both use the NIKKI
  • Posted 20 Mar 2011 09:51
  • By kevin_t
SMV (Konecranes) 4632CC5
Tusk 500PGH14
