Cat NRR35/2NL03433
Does anyone know what code 84 and 22 mean?
  • Posted 30 Nov 2010 00:50
  • By ben_g
  • joined 12 Feb'08 - 60 messages
Do you know what a code 30 is on the NRR35 2NL02132
Tanks
  • Posted 2 Mar 2012 17:50
  • By onyt
  • joined 2 Mar'12 - 6 messages
  • Tamaulipas, Mexico
Code 22
Code Title: Power Panel Overheated
Reason: The temperature signal from the HT exceeded
maximum value.
System Response:
1. Alarm sounds: Yes
2. Operator's Display: Power Panel Overheated, allow time
to cool...
3. PC Contactor: De-energized
4. VFC Display: 22
5. Speed Limit: 0.0 mph
How to Clear : The key switch must be cycled OFF/ON to
clear this fault.
Possible causes:
1. The Power Panel may be overheated...allow to cool.
2. The HT sensor may be bad or disconnected from the CCM.
3. The battery may be discharged or have a bad cell.
4. The CCM may be bad.
5. The Power Panel Driver Assembly may be bad.
6. The Vehicle Manager may be bad.
Corrective Actions and
Checks
Run tests:
* A10 - Panel Temperature Sensor Voltage
* I12 - Power Panel Temperature Limit Signal
1. Check the cables between:
* HT sensor and CCM
* CCM and Vehicle Manager
Code 88
Code Title: Lift Bypass Switch Activated
Reason: Optional lift cutout switch has been activated
System Response:
2. Operator's Display: CODE 88...Press lift bypass switch to
continue lifting
3. PC Contactor: Energized
4. VFC Display: 88
5. Lift Speed Limit: 0.0 mph
How to Clear: Press lift bypass switch to continue lifting.
Corrective Actions and Checks: None.
Regards
  • Posted 30 Nov 2010 02:00
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
ROYPOW
Toyota 8FD45
Terberg YT222
ROYPOW
Muncie, IN, United States
