Toyota 7FGU30 Serial Number 69543
Lift accelerates correctly until you push the pedal down to the floor. Then the throttle cuts back to idle and will not accelerate. Shut lift down then restart, throttle works fine until you push the pedal to the floor again. Jumped wire connection for codes, lift is flashing code 11. Saw a post for similar problem but the fix was never posted. Thanks for the help.
  • Posted 16 Nov 2010 03:10
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
if the floor board is out, put it back. if not, repair or replace the stop which is a bolt with a jam nut... must be in place to prevent over rotation. it is quite common for operators to tamper with them to try to go faster
  • Posted 16 Nov 2010 05:04
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
