Cat EP18KT drive gear
Hi,
I've got a Cat EP18KT (2000) with a noisy right drive gear. This costumer has two of these trucks with the same problem, according to them since new. It is a high (like whistling) sound. Is this a common problem ans what is it caused by?
Can someone supply a shop manulal of this gearbox? e-mail in profile.
Regards,
Frits.
  • Posted 27 Oct 2010 20:35
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
This is a known problem.
the problem is in the gearbx, if you tighten the drive wheel it will disapear for a week or two, I think there is a service buleting aboute this problem, MITSU changed gearbx in 2002 because of this. I can try to find old paper if you need.
  • Posted 5 Nov 2010 08:14
  • By bjarte
  • joined 24 Sep'09 - 63 messages
  • 5911 Alversund, Norway
post at 2talservice dot no
Indeed it turned out to be the drive motor bearings. Thanks for your help.
  • Posted 29 Oct 2010 21:56
  • By frits_f
I have beeing servicing 4 or 6 trucks these model for years and never had problem with transmissions. i agree it is more possible to be bearings. some times when hard grade brushes installed not beeing seated well.
  • Posted 28 Oct 2010 11:53
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
Check your E-mail
  • Posted 28 Oct 2010 07:06
  • By truckparts123
  • joined 11 Oct'08 - 16 messages
  • New Hampshire, United States
rdsmith100@gmail.com
Well I can't imagine the noise is this loud all that 10 years. I'm going to unmount the motor and check the bearings.
Thanks for your support.
  • Posted 28 Oct 2010 01:22
  • By frits_f
It is more likely to be the drive motor bearings making the noise (which is very common) and usually causes no problems. If the noise has been there for 10 years, why worry about it now?
  • Posted 28 Oct 2010 00:00
  • By AndyPandy
