Toyota LPG
Toyota LPG Model 406FG25 Ser No E22117.
Can anyone tell me what grade of Hyd oil I should use in this truck 32,46 or 68's it has a clamping attachment fitted if thats makes a differents, also what is the pressure relief valve setting in bar or psi.
Thanks
Pete
  • Posted 16 Oct 2010 21:32
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
also forgot to answer you, the Relief pressure should be about 2600 for the lift and 2200 for tilt, consult the clamp manufacturer for the proper relief setting to use with the attachment. you may want to install an aux relief block you can switch if you use more than one attachment with this truck.
  • Posted 18 Oct 2010 08:42
  • By steponmebbbboom
ok. stepon
but the 46 works miracles when the pumps are already in the basement and do not forget the ideal temperature of the oil work. the machine will not operate well when it's hot. really there in Canada the weather is cooler so the need for an oil according to the climate state. a hug
Ouvir
Ler foneticamente
  • Posted 18 Oct 2010 08:03
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
i would use AW32 in your climate, spain/portugal 46 is the norm because the climate is more temperate.
  • Posted 18 Oct 2010 06:11
usualuse the 46 that is best suited to such equipment. there is no problem. the 68 does not use due to a higher density and strength a little work the pump
  • Posted 18 Oct 2010 05:25
  • By AMartins
Crown RR5225-30TT321
SMV (Konecranes) 4545CCX5
