Crown Walkie
I have a Crown PE 4000-60 walkie and there are 2 working lights on the posts. The problem is when I put the new bulb on the light stays on for one second and then they both burn out. I have 24V DC right at the bulb and there is a fuse for the 2 lights and a fan but the fuse is not blowing and the fan works just fine. There is a relay which controls these 2 functions but if it was a bad relay then the fan wouldn't work either, so I think and I could be wrong. Any suggestions would be great.
  • Posted 4 Aug 2010 04:40
  • By ronEIL2010
  • joined 28 Apr'10 - 6 messages
  • British Columbia, Canada
please put the serial number for a better diagnossis
  • Posted 6 Aug 2010 02:01
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
your lights are factory installed?
because if not, the problem is there. you must reinstall the lights
on another point. have you a wiring diagram?
  • Posted 6 Aug 2010 01:59
  • By raul_s
I manage a large fleet of forklifts and after years of battling lighting issues, with the cost of bulbs, and labor to troubleshoot and repair lighting I finally replaced all my lighting with LED. By going with LED has really put me out of the lighting and light bulb business. We repaced lighting as they failed and ordered new equipment with factory LED lighting by doing it this way eased the cost some by spreading it out over a period of time. Know that we have 100% LED including strobes and mni light bars our down time for lighting issues is almost 0%.
  • Posted 5 Aug 2010 08:17
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
Okay tried it all and still nothing both lights blow after a second. Boggles my mind.
  • Posted 5 Aug 2010 04:41
  • By ronEIL2010
Ok I will try that thanks.
  • Posted 5 Aug 2010 02:33
  • By ronEIL2010
Then if all is wired properly I would suggest checking the bulb's socket for a short. If it is ok, do the "belt & suspenders" routine - double check the wiring.
  • Posted 5 Aug 2010 01:41
  • Modified 5 Aug 2010 01:43 by poster
  • By johnr_j
Well I got the bulb off of another walkie which is the exact same system and it was working fine on the other one. I did "rewire" it because all the wires were smashed and was sure to follow where they went before.
  • Posted 5 Aug 2010 01:12
  • By ronEIL2010
Start by verifying that the bulb is rated for 24 volts & not 12 volts.
  • Posted 4 Aug 2010 11:12
  • By johnr_j
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Morooka MFD20
REPOWERTEK Inc
USD1
Morooka MFD20
