Probelm with easiopc
Not sure if the model I selected was the right one but my picker has the model # right on it
Model=EASiOPC3OTT
Thing works fine 80% of the time but every now and again I go to start it up and it does the self test and then 3 odd beeps and it says "error code 6K" and then it moves very very slow and we can't get any work done in it for like 2-3 hours then it randomly starts working again. No idea whats wrong and I don't know where to look up this error code any help would be great thanks
It is also charged when it happens
  • Posted 19 Jun 2010 05:33
  • By tim_r
  • joined 19 Jun'10 - 1 message
This is a mast limit switch error code. If you raise the platform up, or look over the top of the tractor you will see two boxes with two limit switches - small boxes size of a small matchbox. It sounds like you may have one damaged or out of adjustment
  • Posted 24 Jun 2010 23:36
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
does this only happen shortly after charging?
have you checked the "Mast height switches" for proper operation?
  • Posted 19 Jun 2010 07:24
MAXAM Tire, Inc.
