CROWN M#FC 4010 - 40 TT188 S# 9A125981 - Intermit hyd Tilt
Hello All,
We have a crown that when lifted past the height limit switch ( Top left of mast) It will not tilt fwd or back and sometimes won't lift at all. Does not do it all the time. Anyone run into this problem and what was the fix???? THX
  • Posted 12 May 2010 03:46
  • By Prentice
or it may be that one of the tilt cylinder eyes have unscrewed a bit from the cylinder causing maladjustment of the cylinders, which in turn will cause the switch and or linkage to the switch on the tilt cylinder to be out of adjustment.
but the switch is where I would start looking.
  • Posted 17 Jul 2010 20:48
if not switch or associated wiring could be the lift interlock module or card/relays depending on which is fitted
  • Posted 17 Jul 2010 20:26
  • By andy_n
  • joined 31 Aug'08 - 1 message
  • Victoria, Australia
Start looking at the switch on the tilt cylinder. It could be bad, mis-adjusted, and open intermittenly. It is not going to tilt forward if the switch tells the truck it is always tilted forward. It is not going to lift if the switch is open once you get past that switch on the mast.
  • Posted 14 May 2010 11:58
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Toyota 02-8FD25
SMV (Konecranes) 12-1200B
