TCM FTB18-7 Serial # 83B00268
The mast will jerks when lifting. This only happens every third or forth time. No other problems with the lift. The hydraulic fluid level is correct. The hydraulic system is self bleeding. All the cylinders look good, no scoring or damage. Mast rails are clean and lubricated. Thanks for the help.
  • Posted 15 Dec 2009 05:14
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
when you say "jerks when lifting";
is it only when loaded, or unloaded,
is it staging correctly?
is this a 2, 3, 4 stage mast?
is it the carriage that bounces,
and how much is each jerk, 5 inches? a foot? 1/2 inch shudders?
does it do it once and that is it for the hour or every 4 times you lift above 6 inches off the ground?
by the way, I heard that time spent fishing does not count against your allotted time on earth...
  • Posted 15 Dec 2009 07:39
  • Modified 15 Dec 2009 07:40 by poster
UN Forklift FD20-35FJM3
Taylor T650L
