P4000 Cat
I was wondering if the connecting pins inside the connectors that plug into the throttle body of the fuel system is available or do i have to purchase an entire harness my problem is a broken wire that is to short to splice and the pin is not in good enough shape to solder. Thanks for any help in this matter.
  • Posted 8 May 2009 01:54
  • By windbreaker_07
  • joined 30 Mar'07 - 4 messages
  • Mississippi, United States
call the cat dealer
they may have to call the factory to get the part numbers
my friend had the same issue
he got the parts for the harness (rats ate the connectors lol)
when in the past (and up until very recently) he would have had to replace the entire harness
they probably would have numbers for the disconnect tools too
ive had those small wires break at the crimp on the pin in these nissans
ill take them out of the connector
un crimp them as good as i can
cut back the wire strip it and re-crimp and put a small bit of solder and put the pin back in
  • Posted 10 May 2009 12:39
  • Modified 10 May 2009 12:42 by poster
  • By justinm
If you ever have to replace a harness it is a good idea to cut off all of the good plugs from the old harness. Saving these connectors has saved me from having to re-wire a few of my customer's trucks. At my dealer I believe we sell the harness for around $900, so repairing the harness has been a substantial savings for them. But if you can get the connectors and pins that is even better.
  • Posted 10 May 2009 12:24
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
it has a nissan engine the serial number is at3505918. if u can purchase just the pins and the pusher to push out the pins let me know where i need to order them from please i need a good stock of these pins
  • Posted 9 May 2009 00:27
  • By windbreaker_07
i think if it has a nissan engine (mid 2004 and later) you can purchase plugs and pins individually
up until recently you had to buy the entire harness but they changed that
im not sure about other series though
whats the serial number?
  • Posted 8 May 2009 07:18
  • By justinm
