clark CF40B power steering leaking right after turn off
I have an old clark cf40b and I noticed power steering fluid under it, alot. What's happening is that when the engine runs evrything works fine, but once I shut off the engine the fluid comes out tru the cap under pressure, i can hear it hissing. What's causing this?
I topped it off and again did the same thing. It has the power steering pump which is in the end of the alternator.
Any input is appreciated.
  • Posted 11 Feb 2009 15:08
  • By kevin_b
  • joined 11 Feb'09 - 2 messages
  • Illinois, United States
The p/s pump is faulty & pulling air in from around the shaft that drives the pump. I don't believe any kits are available to rebuild the pump- a replacement pump would be needed.
  • Posted 4 Jun 2013 08:22
  • Modified 4 Jun 2013 08:23 by poster
  • By bbforks
Where is this air coming from, It's not puking it out while the engine runs even if I turn it all the way left or right but the moment I stop the engine it spills out and it's foamy.
There is only one hose comming out of this pump going to the cylinder I guess, so where's the air coming from??
Thanks
  • Posted 13 Mar 2009 15:40
  • By kevin_b
Is the oil that overflows the resivour foamy? the theroy of overfilling os ok but it would overflow the tank when you turned the steering to the small side of the cylinder,it would overflow at that time even if the engine was running.sounds like your *** air,if the oil is foamy after the engine is shut off and pukes the resivour its air.
  • Posted 28 Feb 2009 14:01
  • By howard_w
  • joined 28 Feb'09 - 7 messages
  • Colorado, United States
You can't fill that tank all the way because the level changes as you steer one way or the other. When the cylinder is extended all the way it has more fluid in the cylinder tube than when it is retracted with the shaft inside the tube so the level in the tank goes up and down. If you fill the power steering tank all the way it will "push" some of the oil out of the cap.
  • Posted 21 Feb 2009 03:55
Mitsubishi FD200
Nagano NUL120-6
edition #1257 - 20 November 2025
Mitsubishi FD200
Nagano NUL120-6
Mitsubishi FD200
Nagano NUL120-6
