Steering Problem 025FD30
Hi, I need help for the following:
I have a 025FD30 of 1989 with hidraulic brakes that has a problem, the steering is hard I mean that I have to make effort to turn it. I brakes well.
I already measured the pressure on the steering box and it return 50 bar, and i think it must be 85 bar. We already changed hidraulic block and everyting is ok (presure 180 bar for lift and tilt). Is there somebody who can help to increase the steering pressure? where can it be done?
Thanks
  • Posted 22 Jan 2009 02:13
  • By goncalosousa
  • joined 12 Sep'05 - 42 messages
  • Leiria, Portugal
Hello goncalosousa, We had i similar problem with a 5FGCU25. We found the top end of the steering shaft the universal and bearings worn and damaged. just a quick check to save buying a new steer pump
  • Posted 22 Jan 2009 22:51
  • By Prentice
Thank you Luis, can you tell me where is located that relief valve?
Is it possible to send me a draw showing it?
I will be very gratefull.
my contact is gofiolso at sapo dot pt
Thank you very much for your help
  • Posted 22 Jan 2009 18:17
  • By goncalosousa
  • Leiria, Portugal
Hello
Pressure must be from 75 to 85 Kg/cm2. First you have to check the relief valve condition. If valve is OK you can set up it adding or removing shims.
  • Posted 22 Jan 2009 06:33
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
Brothers Adolf ("Adi") and Rudolf ("Rudi") Dassler split their shoe company after WWII due to a bitter feud, and established the rival companies of Adidas and Puma. Their personal animosity and business rivalry divided their German hometown Herzogenaurach. The town became known as "the town of bent necks" due to the intense loyalty to each brand.
Taylor TT300
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1251 - 9 October 2025
