Brake valve problem Genie S125
Hi, I have a problem with a Genie S125 (S/N:S12505-1161) year 2005, I've been trying to fix it for a while but I'm about to give up.
The platform works perfectly! The problem arises when I try to go front or reverse; the DCON doesn't power the brake valve, instead when I activate the wheel steering, the brake valve is unlocked.
I checked the extendable axis switches, I checked the micro drive enable, all ok!
I also checked via WebGPI, when I turn, under the brake valve item I see written (in green) "Released", when I try to go forward or backward it remains yellow with the word "applied". I have no errors even in webgpi.
What do you recommend?
Thank you!!!!
Daniele
  • Posted 8 Sep 2025 22:10
  • By daniele_t
  • joined 3 Nov'17 - 3 messages
  • Palermo, Italy
Maxlion FD50T
SMV (Konecranes) 4531CC5
Yale Lift Truck Technologies
