Password
Is there anyway to access the menu to clear codes without knowing the password? 55555 did not work and I have no documentation on the lift.
  • Posted 9 Apr 2025 22:13
  • By Zeeker
  • joined 9 Apr'25 - 2 messages
  • Arkansas, United States
Thanks!
Try last 5 digits of serial number. Key pad only does 1-5
6=1 7=2 8=3 9=4 and 0=5. Ie. serial 14632 would be keyed in as 14132. 19746 would be keyed in as 14241
  • Posted 22 May 2025 12:04
  • By Roy_Baumeister
  • joined 9 Aug'23 - 9 messages
  • British Columbia, Canada
Zeeker,
Without having the correct password, you will not be able to clear the codes. If you know where the lift came from, try using the zip codes around that area. If the number of attempts is turned on, you only have nine tries before it will time out. Good Luck.
  • Posted 14 Apr 2025 22:26
  • By Fishmech
  • Virginia, United States
SMV (Konecranes) SL37-1200A
Ice 28INCH-AUTO-SCRUBBER
USD8,350
