GP50K1 shuts off while driving
I have a CAT GP50K1 s/n: AT33B50276 with the inline 6 engine (im not sure what the engine designation is) It starts and runs fine but once you start driving it after a few minutes ouf operation it shuts down. After a few minuets it will restart. i figured out that it was cutting the fuel at the lock off so i jumped the lockout to get it back to the service area it stayed running but ran poorly.
both fuel injectors replaced and the maf sensor
im curious to what the computer would need to see in order to shut the lock off (oil pressure , overheat , cam/ crank sensor etc....)
it does not have a display only the triangle with an exclamation point
any help would be appreciated
thank you
  • Posted 5 Mar 2024 10:37
  • Modified 6 Mar 2024 05:52 by poster
  • By Josh_Wexler
  • joined 5 Mar'24 - 1 message
Do you know AGAI?
