Maintenance indicator light reset
Hyster s80xm, I believe Serial #309327
How does one reset the MIL?
Forgive my ignorance, this is just a little lift we have for moving metal here at the shop and I have zero information on it.
  • Posted 16 Jan 2024 07:37
  • By Josh_Taylor
  • joined 16 Jan'24 - 1 message
  • Kentucky, United States
Josh,
The MIL light only comes on when a code sets or you have a wiring issue with the circuit. Remove floor plate and locate a square four pin connector. They should be labeled A, B, C, D or 1, 2, 3, 4. Jump the A to D or the 1 to 4. Watch the MIL light and see if you get codes. Code 166 should come up three times to let you know the circuit is good. After that you should see additional codes. Check your coolant level and the oil pressure sending unit mounted under the distributor. If your leaking oil, replace. Good Luck.
  • Posted 30 Jan 2024 04:51
  • By Fishmech
  • Virginia, United States
Crown RR5225-30TT321
SNORKEL A46JE
SNORKEL A46JE
SNORKEL A46JE
Yale Lift Truck Technologies
