Forklift upgrades
I work in a facility that we move plates of metal and put them on a machine but we have to lower the angle on the forks and stomp on the break to load our machine which is very tricky cause it can cause the machine damage if there was a push bar or something like that to push the material off of the forks that would be amazing
  • Posted 30 Jun 2023 15:42
  • By Speedy
  • joined 30 Jun'23 - 1 message
  • Kansas, United States
Jason Oyler
As others have already stated, probably the ideal attachment would be a Push/Pull or Slipsheet attachment.
Would be worth contacting a supplier to enquire iof the attachemnt would be suitable for your use as this type of attachment is normally designed for pulling and pushing products from/into containers and then onto pallets provided a slipsheet is available under the product.
It might work for the metal plates but I guess it depends on how you get the metal plate onto the slipsheet attachment first.
  • Posted 6 Jul 2023 21:58
  • By Tat2dPete
  • joined 29 Sep'20 - 41 messages
  • Strathclyde, United Kingdom
Pete
It sounds like what you need is a Load pusher. they are availalble from Cascade Corp.
  • Posted 6 Jul 2023 21:36
  • By duodeluxe
  • United States
duodeluxe
check with
Accessory manufacturers about attachments
For your specific needs someone like cascade etc
  • Posted 1 Jul 2023 08:43
  • By John_Bradley
  • joined 10 Aug'22 - 263 messages
Jb69
Mitsubishi FGE35AT
Toyota 4FD240
Hyster
Muncie, IN, United States
