CAT GP40N Blowing ECM
Got a P04 code coming up, which is ECM communication fault. Unit cranks but wont fire. Swapped ECM out and truck ran fine. Fitted new ECM.
2 weeks later same code and fault came up, ECM faulty again, tested on another unit. Anyone came across an issue like this? Seems like a wiring issue or a shorted module/sensor may be blowing the ECM, but then again I thought it would have blown a fuse before it blew the ECM. Don't want to put another ECM without locating the cause. Not really sure where to go next other than pulling the whole harness apart
  • Posted 25 Apr 2023 21:16
  • By Jofork
  • joined 4 Jan'17 - 23 messages
Probably too late to help, but check your charging voltage...should be no more than 14.4VDC
  • Posted 28 Mar 2024 08:02
  • By Bryan_Ayers
  • joined 27 Mar'24 - 4 messages
  • Wisconsin, United States
Noblelift
Taylor TT300
USD98,500
SMV (Konecranes) 4632CC5
Kai von Berg Kai von Berg
Noblelift
