Fluids and maintenance
I have a small welding business and I use an old Yale forklift to move steel. I can't find any kind of maintenance manual for a forklift as old as mine. Im trying to figure out what type of hydraulic fluid I need. Id also like to find the types of trans fluid, oil, etc.. I need.
Its an old Yale model GLP040ADJUAE085LPS
thanks for the help
  • Posted 11 Jan 2023 14:07
  • By AZguy
  • joined 11 Jan'23 - 4 messages
  • Arizona, United States
Yes that's the info I was looking for, thanks for the help
  • Posted 16 Jan 2023 10:47
  • By AZguy
As far as the hyd oil 32,wt oil is fine in that truck also for transmission use dextron III by Gm. For motor oil l believe this truck uses a Mazda va engine overhead valve if so 10w30wt oil is good. Hope l was of help.
  • Posted 13 Jan 2023 11:32
  • By Scott_
  • joined 16 May'21 - 316 messages
Scott
Esie Cortez Esie Cortez
