Forklift won’t lift past the first stage
Electric forklift won't Lift past the first stage with 2 loads(it has a single double attachment). Any ideas? I'd appreciate it
  • Posted 8 Dec 2022 16:25
  • Modified 8 Dec 2022 16:25 by poster
  • By Kevin_D
  • joined 9 Sep'22 - 3 messages
check the main relief pressure, should be 2630psi.
if that checks ok then i'd pull the center cylinder rod assy out and check the safety valve in the base of the rod, they are bad about coming apart and causing many lifting and drifting issues.
  • Posted 10 Dec 2022 23:47
Crown CG33P5
Aichi RX07B
Esie Cortez Esie Cortez
