BT ERROR CODE 3.564
BT LWE180 error 3.564 can not find this error code in my book Does anyone know what this code is?
  • Posted 19 Aug 2022 01:25
  • Modified 19 Aug 2022 01:57 by poster
  • By richard_m
  • joined 11 Apr'13 - 110 messages
  • lancashire, United Kingdom
richardsforklifts @gmail.com
Just had this fault. Turned out to be the battery flat. The on board charger was draining battery and not charging when plugged in.
Charged truck from another charger. (not an on-board charger) connected battery to truck and working. Tested on board charger again and it was dragging the battery down. Even when plugged into mains and supposedly charging. Fitted new charger all good.
  • Posted 7 Oct 2025 17:50
  • Modified 8 Oct 2025 08:09 by administrator
  • By ROBERT_Wilson
  • joined 6 Oct'22 - 3 messages
  • United Kingdom
robbienwilson
Q10 is the line contactor on the far-left top. Open circuit on the contactor. Replace the unit or repair associated wiring. The unit is the most common problem.
  • Posted 12 Sep 2025 19:05
  • Modified 13 Sep 2025 09:22 by administrator
  • By ROBERT_Wilson
  • United Kingdom
robbienwilson
All depends which BT truck you have i suppoose :)
3:564 Low current
Allt stoppas direkt, parkeringsbroms aktiveras och huvudkontaktor öppnas.
The amperage is below the limit
value 100mA on the output to
brake (Q10)
* Low power consumption
or break
1) Check wiring and component after the break
Disconnect the battery
Visually check the wiring
harness
Using instruments, check
that there is no break in
any wire
Check the Ohms and the
Amperes of the component, compare them to the
setpoint values, and replace the unit if they are
outside the accepted
range.
Reconnect the battery.
Measure and check the
voltage for the activated
functions
  • Posted 19 Aug 2022 01:31
  • By andrew_k
  • joined 17 Mar'07 - 334 messages
  • England, United Kingdom
Terberg RT223
SNORKEL A46JE
Muncie, IN, United States
Terberg RT223
SNORKEL A46JE
