Hyd Issue
Replaced the Hyd Oil for the 750-32drtt. Bled the system. Checked the K2 relay, PRV 4 and replaced 2 solenoids because they tested bad. Do not have tilt, extend or retract functions. The pump is working as the lift still works. Any ideas?
  • Posted 20 May 2022 23:45
  • By Kyle_Johnstone
  • joined 20 May'22 - 3 messages
  • Wisconsin, United States
Check continuity of each wire of the mast electrical cable. Access by removing left front red cover, and metal cover on top of the carriage
  • Posted 25 May 2022 04:30
  • By Triggs
Terberg YT220
Mitsubishi FD200
Oxford Ct, United States
