P5000 E27 K25
SN AT3503871
Don't know how old the lift is (at lest 10 yrs) but it only has 1075 hours. Had water in the oil so changed it twice and let it run for about an hour to burn off the rest. Noticed after about 45 minutes I heard the motor die. Walked over to the barn and fired it back up. Let it run another 15 or so and shut it off.
Next day try to start it and it does start but I have code E-27, CPS error and dash panel lights are flashing, running a bit rough also. Other write ups on site list it may be the plugs and/or coil packs. Pulled plugs and they look good, have ordered a new set.
Might have found the diagnostics port under the cup holder. Its a 10 pin rectangular port but is not a ODB2 type.
  • Posted 17 Apr 2022 02:16
  • By AllDodge
  • joined 17 Apr'22 - 5 messages
  • Kentucky, United States
CAT P5000 AT3503871
Replace cam and crank sensor, pedal dace its running without issues again. Hope it stays that way
This forum is dead
  • Posted 1 May 2022 21:49
  • By AllDodge
CAT P5000 AT3503871
The forum is really dead, must not have hardly anyone here.
In any case to maybe help someone like me just looking for help. The code is back and motor runs smooth but does start hard. Battery is a bit weak and cranks maybe 5 seconds before it runs. Thinking it might be the crank sensor, figure might replace it. Will look at both crank and can sensors to see if anything is noticeable
  • Posted 26 Apr 2022 08:09
  • By AllDodge
CAT P5000 AT3503871
Replaced coil pack, did the pedal dance and its back running without issue
  • Posted 23 Apr 2022 03:30
  • By AllDodge
CAT P5000 AT3503871
Plugs replaced and error remains. Started disconnecting coil pack and number 3 does nothing when disconnected. Coil pack 22448-AR215 and appears to be about $85 each and up
Doesn't appear there are very many users on the forum.
  • Posted 20 Apr 2022 07:25
  • By AllDodge
CAT P5000 AT3503871
Terberg RT403
Kalmar DRF450-70C5XS
Esie Cortez Esie Cortez
Oxford Ct, United States
