Use of LPG trucks in industrial freezers
My research tells me use of electric trucks in freezers is the best option to prevent CO exposure. Further, it is obvious that truck maintenance is critical if using LPG in poorly ventilated spaces (IE freezers). Does anyone have any data they are willing to share regarding exposure values found when using LPG inside of freezers? Also any thoughts/hard numbers about increased costs due to more ventilation exchanges? Thanks!
  • Posted 21 Oct 2008 12:18
  • By Stefnbama
  • joined 21 Oct'08 - 2 messages
Quite a comprehensive and interesting answer there John. Would be interested to discuss further. We are developing new emission strategies to assist with these types of application and would like to hear your take on some of them. Can get me at 03 9587 9488 if you wish.
  • Posted 27 Oct 2008 11:09
  • By stephen_g
  • joined 24 Oct'08 - 2 messages
  • Victoria, Australia
Three other factors need to be considered wherever forklift emissions are of concern:
1. Is your LPG fuel composition regulated? If it is propane what is the limit to the amount of other hydrocarbons? If it's a propane-butane mix what ranges of those gases and other gases are allowed. In Australia LPG for forklifts is an unregulated propane - butane mix. As a result any engine without an O2 sensor and a mechanism to adjust the air fuel ratio can have very high CO outputs as gas bottles are changed. In testing of mostly new or near new forklifts the CO readings were from 550 ppm to ~90,000 ppm (this was outside the instruments accurate range) with a median of 4000 ppm. At 90000 ppm it would take 3 minutes for the CO level in a 50 m long by 20 m wide by 5 m high enclosed space to reach the 8 hour CO exposure limit of 50 ppm - and in 11 minutes the maximum allowed indoor level of 200 ppm. Even at 4000 ppm the times are 1 hour and 4 hours.
2. How well tuned are your forklift engines? In the same testing above, a gasoline engine forklift (and gasoline specifications are very precise here) gave a reading of 22,000 ppm! Obviously the engine was either very much out of tune OR the emission management system was not working.
3. Do you have forklifts with engines with catalyctic converters in situations where forklift use is intermittent? In this testing it was shown that such engines took 13-14 minutes at idle to get too 500 - 800 ppm with the catalyctic converter working. But along the way CO levels peaked at 6,500 - 13,500 ppm. So if the forklift is used intermittently so the catalyctic converter rarely reaches full operating temperature you still have a problem.
Finally, in this study, the engines with consistently the lowest CO emissions were DIESEL engines with levels below 100 ppm. It would take 50 hours of operation to get to 50 ppm in the warehouse above.
In addition a diesel engine produces 30% less heat than an LPG engine doing the same task because the diesel engine is much more efficient.
So in a situation where you had to use an IC engine in a freezer for a short time, diesel would be the best choice
  • Posted 25 Oct 2008 03:33
  • By John_Lambert
  • joined 30 May'06 - 74 messages
Better to strive and experience all life's colours from pain to ecstasy than to exist in a grey life
Many thanks for the replies.
  • Posted 24 Oct 2008 11:52
  • By Stefnbama
We (Micro Fresh Filters) have a range of catalytic exhaust filtration products that will reduce CO (as well as NOx and HC) by up to 99%.
Still probably not ideal in a completely closed environment as by-product is then CO2 and H20, but may be suitable for some applications.
Contact info available at www.microfreshfilters.com
  • Posted 24 Oct 2008 11:15
  • By stephen_g
100% correct about using electric in freezers. You should not contemplate using LPG trucks under any circumstances. Four basic reasons:
First, is related to energy efficiency, the air in the frreezer is not changed, (other than when the doors are open), just recirculated. This greatly reduces the energy input to chilling "new" air at ambient temperature.
Second, due to the first even an LPG engined truck working as intended will emit a small amount of CO, accepting this, the level of CO will build up over days and months to potentially high and dangerous levels.
Third, the truck emits heat which hurts the thermal economy of the freezer.
Fourth, the truck fuel system / emission control system may not be able to effectively control the air fuel ratio and hence CO emission level due to the temperature in the freezer, (dependent on how cold it is).
Hope that this is of help, regrettably all the forgoing knowledge is the result of personal involvement in this issue! truck he retom
  • Posted 23 Oct 2008 18:57
  • By clem
  • joined 20 Jan'06 - 7 messages
  • Berkshire, United Kingdom
SMV (Konecranes) 4632CC5
Advance CS7000
Illinois, United States
USD8,000
Advance CS7000
USD8,000
