Starter Pinion not engaging Ring Gear fully
4Y engine. Toyota number for starter is 28300-22003-71. Denso number on the starter is 228000-4374. Looking at the wear marks on the pinion gear and the ring gear shows that only 60% of each tooth, on both the pinion and the ring gear, engage. Pinion throw is 13 mm.
Has anyone come across this issue?
  • Posted 6 Aug 2021 11:05
  • By Georg
  • joined 7 Mar'14 - 20 messages
1998 426FGCU25 Ser No 67740
Your Part number is incorrect for the starter
28100-20553 RF is correct. It is a genuine toyota reman. Fits all 4y engines. Someone may have goofed along the way and got a automotive one mixed in.
  • Posted 19 Aug 2021 21:29
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
Ring gear is still good and the engine cranks over well. I am just concerned about the incomplete engagement and was wondering if there was another starter available which would provide more pinion throw or if there was a modification I could do on the starter which would provide more throw.
Starter is mounted straight on to the bell housing, with no spacers in between.
  • Posted 9 Aug 2021 16:14
  • By Georg
starter ring in transmission box might worn too much. chance it. remove motor backwards as much it moves. transmission box moves just so much that you can change the starter ring.
  • Posted 9 Aug 2021 00:14
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Combilift Ltd
