Oil for transmission.
Can anyone tell me what oil should be in the transmission of a 1972 Cat t35D.
The bellhousing has oil in it, is this supposed to be a wet system ?.
I'm waiting for the SERVICE SHOP REPAIR MANUAL to arrive for it, but it's going to be another fortnight before it arrives from the states (I'm in the UK).
  • Posted 6 Aug 2021 04:00
  • By fonzie
  • joined 10 Aug'18 - 17 messages
  • United Kingdom
Found the strainer, it was dirty and had specks of aluminium in amongst the dirt, cleaned it out and replaced it.
The transmission fluid was black, although obvious it had been red at some time, re-filled the transmission but the machine still wont move.
I hopeful it's the system that needs priming, can anyone tell me a way to do that with this particular truck
  • Posted 11 Aug 2021 02:38
  • By fonzie
  • United Kingdom
Thank you so much for the reply, I'll have a look for that filter (already got the parts manual so should be able to find it).
I removed the inspection plate at the top of the bellhousing and there is a thin plate held in place by three 17mm bolts, two were loose, the other is missing, any idea what that plate is for ?.
  • Posted 6 Aug 2021 15:07
  • By fonzie
  • United Kingdom
Check the strainer filter in the bottom of the transmission, they block and cause bell housing to fill with oil
  • Posted 6 Aug 2021 08:31
  • By Bttowmotor
  • joined 18 Nov'04 - 14 messages
  • merseyside, United Kingdom
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Aichi SR18A
Linde Material Handling
Oxford Ct, United States
USD1
Aichi SR18A
USD1
Aichi SR18A
